[postgis-devel] Re: PostGIS datastore creation
TECHER David davidtecher at yahoo.fr
Thu Oct 5 14:52:52 PDT 2006
Hi Marc,
Oh U're on a Xen VM, I'm on a Win XP VMWare player :-)
Hum! U're right!
I saw the diff I've got...Since I'm French I've only have problem with
PGOPTIONS where lc_message=C
Indeed PGOPTIONS is not enough for me to pass the regression tests...(by
having  look in regress/run_test)
See http://www.davidgis.fr/download/postgis-1.1.4--regression.pdf
Actually, I've got problem with the word 'ERROR' that came translated in
French in the word 'ERREUR'
from "file"expected but that's all!
So in conclusion, the regression test works with PostgreSQL 8.1.4, Geos
2.2.3, Proj and PostGIS 1.1.4
as U said! ;-)
I don't test PostgreSQL 8.2 for the moment!
By the way, did U try to compil Geos 3.0.0 rc1...I don't succedd! :-(
--david;
Mark Cave-Ayland a écrit :
>On Wed, 2006-10-04 at 23:21 +0100, Mark Cave-Ayland wrote:
>>On Wed, 2006-10-04 at 23:19 +0200, TECHER David wrote:
>>>Hi Mark
>>>Did U succedd using "make check" on win32 with postgis-1.1.4?
>>>I don't !
>>>--david;
>>Hi David,
>>The regression tests are run as part of the installer build script and
>>they all pass for me (currently testing on PostgreSQL 8.1/PostGIS
>>1.1.4/GEOS 2.2.3/PROJ 4.4.9). Which tests are failing for you?
>>Kind regards,
>>Mark.
>Hi David,
>I've just rebuilt the new PostGIS 1.1.4 installer for PostgreSQL 8.2 and
>I am seeing a regression failure - it looks as if pgsql2shp.exe is
>crashing but only against PostgreSQL 8.2 - all the tests pass for me on
>PostgreSQL 8.1 without any problems. I'm trying to get a backtrace, but
>unfortunately the crash reboots my WinXP Xen VM when I try and attach
>gdb :(
>Can anyone else replicate these regression failures against PostgreSQL
>8.2 on Win32?
>UPDATE: I've quickly logged the pgsql2shp.exe command that causes the
>regression tests to fail, and it seems to work fine when I execute the
>command manually from within MingW :(
>Kind regards,
>Mark.
--david;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20061005/5e9d01f5/attachment.html>
