[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com codesite-noreply at google.com
Wed Dec 10 14:48:10 PST 2008
Comment #15 on issue 34 by robe.... at cityofboston.gov: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
Mark,
Hmm didn't quite get that from the reading the docs that PQexecParams
caches the
query plan.  It seemed to suggest the only benefit is that it escapes out
the text
correctly based on data type.  If it cached the plan, then what's the point
of having
PQexecPrepared.
PGresult *PQexecPrepared(PGconn *conn,
                          const char *stmtName,
                          int nParams,
                          const char * const *paramValues,
                          const int *paramLengths,
                          const int *paramFormats,
                          int resultFormat);
Though it would be nice if they actually had some examples in the docs of
these.  I
have too low of an attention span to actually read stuff :).
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
