[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com
Thu Dec 11 08:31:39 PST 2008
Comment #16 on issue 34 by robe.... at cityofboston.gov: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
Mark,
I changed the logic to use PQescapeStringConn insteaad and increased
malloc. I'm
using (char *) malloc(2 * strlen(schema) + 1); syntax instead of
esc_schema =
I assume both are just different ways of saying the same thing. I stuck
with that
since the rest of the code here uses the (char *) and I figure the less
people need
to think about the better or we could change all the code to the shorter
syntax.
Also finally got to test this in ArcGIS in 9.3 and it works beautifully.
I tested with
pgsql2shp testdb "SELECT name, ST_Transform(the_geom,4269) as newgeom FROM
neighborhoods" -f neilonlat
and
also a
pgsql2shp testdb dnd.rems_survey -f survey
One in long lat and the other in MA state plane feet and when I overlaid
them in
ArcGIS they reprojected to the first layer I laid on so lined up nicely.
It would be nice to include this in 1.3.5 now that I'm thinking about it
and that we
will have a 1.3.5anyway. Would anyone have issues if I back-ported to
1.3.5, or do
we not consider this a minor enhancement?
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
