[postgis-devel] Re: trunk: ERROR on spatially-enabling a database
strk
strk at keybit.net
Wed Nov 26 04:24:37 PST 2008
On Wed, Nov 26, 2008 at 12:00:30PM +0000, Mark Cave-Ayland wrote:
> strk wrote:
> >Not sure how to force that as I belive lwgeom/Makefile
> >is based on PGXS ?
> Yeah, this is the one failing with PGXS: it doesn't seem to allow
> external target dependencies as it links the .o files directly :( At
> some point I was hoping to add a separate "alldev" target to all of the
> Makefiles for developer use that would just call the "all" target, but
> also handle the dependencies correctly.
You mean 'alldev' would not use PGXS ?
Would linking all .o of libwlgeom rather then the .a fix the issue ?
--strk;
