[postgis-devel] ESRI link to docs
Obe, Regina
robe.dnd at cityofboston.gov
Wed Sep 10 04:01:48 PDT 2008
>> Obe, Regina wrote:
>> I just noticed ESRI has a link to the PostGIS docs. Kind of
>> heart-warming. Too bad the link to the pdf gives a 404. Perhaps we
>> should fix that.
http://webhelp.esri.com/arcgisserver/9.3/java/index.htm#geodatabases/usi
ng_th485132809.htm
> I've got some contacts at ESRI who should be able to fix that for a
> future version. But if it's a PDF, it's likely that fixing it will
take
> some time, so doing a redirect to the proper thing would work as well
> Is there a permalink they should be using?
> //Magnus
Magnus,
Well there is a redirect in place that redirects doc into documentation.
I suspect the file is just not there anymore and we (Kevin or Mark) has
to revise our build to build the pdf version moving forward.
Paul or Kevin or anyone at Refractions - you happen to know where the
old .pdf is now? I assume its still valid to keep it since it is part
of the current release until we have the kinks worked out in the
automated build process.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
