[postgis-devel] ESRI link to docs
Kevin Neufeld
kneufeld at refractions.net
Wed Sep 10 08:46:02 PDT 2008
Yeah, I've been looking into this pdf thing. I would like to add the
pdf generation to the autobuild process, but somehow we lost the ability
in the Makefile to generate pdfs using DocBook (at least on the system
that is doing the documentation autobuild at the moment). I recall Paul
once created a PDF using the new style sheet - it was nice. I'm waiting
to hear back from him on how he did his magic, but he's away on holidays
until tomorrow.
-- Kevin
Obe, Regina wrote:
>>> Obe, Regina wrote:
>>> I just noticed ESRI has a link to the PostGIS docs. Kind of
>>> heart-warming. Too bad the link to the pdf gives a 404. Perhaps we
>>> should fix that.
> http://webhelp.esri.com/arcgisserver/9.3/java/index.htm#geodatabases/usi
> ng_th485132809.htm
>> I've got some contacts at ESRI who should be able to fix that for a
>> future version. But if it's a PDF, it's likely that fixing it will
> take
>> some time, so doing a redirect to the proper thing would work as well
>> Is there a permalink they should be using?
>> //Magnus
> Magnus,
> Well there is a redirect in place that redirects doc into documentation.
> I suspect the file is just not there anymore and we (Kevin or Mark) has
> to revise our build to build the pdf version moving forward.
> Paul or Kevin or anyone at Refractions - you happen to know where the
> old .pdf is now? I assume its still valid to keep it since it is part
> of the current release until we have the kinks worked out in the
> automated build process.
> Thanks,
> Regina
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
