[postgis-devel] ESRI link to docs
Kevin Neufeld kneufeld at refractions.net
Wed Sep 10 09:03:16 PDT 2008
In the mean time, I found the an old pdf (version 1.3.2) on the server
and modified the webpage with an appropriate URL.
http://postgis.refractions.net/docs/postgis.pdf
which aliases to
http://postgis.refractions.net/documentation/manual-1.3/postgis.pdf
-- Kevin
Kevin Neufeld wrote:
> Yeah, I've been looking into this pdf thing.  I would like to add the
> pdf generation to the autobuild process, but somehow we lost the ability
> in the Makefile to generate pdfs using DocBook (at least on the system
> that is doing the documentation autobuild at the moment).  I recall Paul
> once created a PDF using the new style sheet - it was nice.  I'm waiting
> to hear back from him on how he did his magic, but he's away on holidays
> until tomorrow.
> -- Kevin
> Obe, Regina wrote:
>>>> Obe, Regina wrote:
>>>> I just noticed ESRI has a link to the PostGIS docs.  Kind of
>>>> heart-warming.  Too bad the link to the pdf gives a 404.  Perhaps we
>>>> should fix that.
>> http://webhelp.esri.com/arcgisserver/9.3/java/index.htm#geodatabases/usi
>> ng_th485132809.htm
>>> I've got some contacts at ESRI who should be able to fix that for a
>>> future version. But if it's a PDF, it's likely that fixing it will
>> take
>>> some time, so doing a redirect to the proper thing would work as well
>>> Is there a permalink they should be using?
>>> //Magnus
>> Magnus,
>> Well there is a redirect in place that redirects doc into documentation.
>> I suspect the file is just not there anymore and we (Kevin or Mark) has
>> to revise our build to build the pdf version moving forward.
>> Paul or Kevin or anyone at Refractions - you happen to know where the
>> old .pdf is now?  I assume its still valid to keep it since it is part
>> of the current release until we have the kinks worked out in the
>> automated build process.
>> Thanks,
>> Regina
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
