[postgis-devel] Multi-Lingual Docs
Kevin Neufeld
kneufeld at refractions.net
Fri Oct 23 18:04:02 PDT 2009
Ah, of course. That certainly would be easier to maintain, but it does
necessitate consistent xml styles across revisions.
-- Kevin
Paul Ramsey wrote:
> Another approach to maintenance is to have the language maintainers
> record a "last revision" number in the readme when they've finished a
> translation pass. Then the next time they come in, they can generate a
> diff between that revision and head to see what has changed.
> P.
> On Sat, Oct 24, 2009 at 11:52 AM, Kevin Neufeld
> <kneufeld at refractions.net> wrote:
>> I think it's a great idea. I was noticing when we started the documentation
>> face lift how docbook does indeed make multilingual support easy.
>> The only thing is, whenever someone submits a patch to the documentation,
>> they'll have to remember to record the patch in a documentation bug report
>> so that someone qualified can tackle the translation to other languages. I
>> foresee one documentation bug report category for every language we plan to
>> support.
>> Cheers,
>> Kevin
>> Paul Ramsey wrote:
>>> Hi All,
>>> I'm at the FOSS4G code sprint today, and have been discussing
>>> multi-lingual documentation with Til Adams and Daniel Kastl. Given
>>> that we've had 3rd party translations to fr and pt in the past, it
>>> would be great to pull the i18n community into the main documentation
>>> process, by making the docs multi-lingual.
>>> This project seems to provide a template for doing multi-lingual
>>> docbook in unified way, with a minimal amount of duplication (in
>>> particular, we want to avoid duplicating things like the diagram
>>> generation and the SQL code examples and so on across translations).
>>> http://docbooksml.sourceforge.net/
>>> The translations then end up looking like this:
>>> <title>
>>> <phrase lang="en">What is DocBook.sml?</phrase>
>>> <phrase lang="de">Was ist DocBook.sml?</phrase>
>>> </title>
>>> The translation blocks can be as granular (as above) or blocked (doing
>>> whole sections in translation or whole chapters) as you want. So we'd
>>> probably have different granularity in different sections. Reference
>>> manual very granular (because there's so much code example and
>>> parameter stuff that is language-independent) and tutorial sections
>>> less granular (because there's so many translatable words in blocks).
>>> Til is doing some experiments with docbooksml and will show us what a
>>> working multi-lingual set-up would look like when he gets it running
>>> (posting a postgis source tarball with the multilingual approach
>>> implemented that we can download and try). Then we can decide
>>> how/if/when to integrate it into our working doc system.
>>> Thoughts?
>>> Paul
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
