[postgis-devel] Multi-Lingual Docs
Till Adams adams at terrestris.de
Fri Oct 23 19:47:25 PDT 2009
except that my name is written with two "l" - Till, Paul already told
everything right. What I am doing in the moment is figuring out how to work
with that DocBook.sml. After that first step, I hope I can write a small
howto on that. Then we are going to start with the translation, but as we
are all busy (and I have another ten days here in Australia), don't expect
too much soon...
But once started that, I think it should be possible, even as we have some
students reachable in our company.
Happy to give my 2 cent back to the great software PostGIS - kind regards,
Till Adams
----------------ursprüngliche Nachricht-----------------
Von: "Kevin Neufeld" kneufeld at refractions.net
An: "PostGIS Development Discussion"
Datum: Fri, 23 Oct 2009 18:04:02 -0700
> Ah, of course. That certainly would be easier to maintain, but it does
> necessitate consistent xml styles across revisions.
> -- Kevin
> Paul Ramsey wrote:
>> Another approach to maintenance is to have the language maintainers
>> record a "last revision" number in the readme when they've finished a
>> translation pass. Then the next time they come in, they can generate a
>> diff between that revision and head to see what has changed.
>> P.
>> On Sat, Oct 24, 2009 at 11:52 AM, Kevin Neufeld
>> kneufeld at refractions.net wrote:
>>> I think it's a great idea. I was noticing when we started the
>>> documentation
>>> face lift how docbook does indeed make multilingual support easy.
>>> The only thing is, whenever someone submits a patch to the
>>> documentation,
>>> they'll have to remember to record the patch in a documentation bug
>>> report
>>> so that someone qualified can tackle the translation to other languages.
>>> I
>>> foresee one documentation bug report category for every language we plan
>>> to
>>> support.
>>> Cheers,
>>> Kevin
>>> Paul Ramsey wrote:
>>>> Hi All,
>>>> I'm at the FOSS4G code sprint today, and have been discussing
>>>> multi-lingual documentation with Til Adams and Daniel Kastl. Given
>>>> that we've had 3rd party translations to fr and pt in the past, it
>>>> would be great to pull the i18n community into the main documentation
>>>> process, by making the docs multi-lingual.
>>>> This project seems to provide a template for doing multi-lingual
>>>> docbook in unified way, with a minimal amount of duplication (in
>>>> particular, we want to avoid duplicating things like the diagram
>>>> generation and the SQL code examples and so on across translations).
>>>> http://docbooksml.sourceforge.net/
>>>> The translations then end up looking like this:
What is DocBook.sml?
Was ist DocBook.sml?
>>>> The translation blocks can be as granular (as above) or blocked
>>>> (doing
>>>> whole sections in translation or whole chapters) as you want. So we'd
>>>> probably have different granularity in different sections.
>>>> Reference
>>>> manual very granular (because there's so much code example and
>>>> parameter stuff that is language-independent) and tutorial
>>>> sections
>>>> less granular (because there's so many translatable words in
>>>> blocks).
>>>> Til is doing some experiments with docbooksml and will show us what a
>>>> working multi-lingual set-up would look like when he gets it running
>>>> (posting a postgis source tarball with the multilingual approach
>>>> implemented that we can download and try). Then we can decide
>>>> how/if/when to integrate it into our working doc system.
>>>> Thoughts?
>>>> Paul
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
