[postgis-devel] Installing topology.sql
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Dec 10 08:34:35 PST 2010
strk wrote:
> I'd just generate the topology.sql file by default and install near
> the others (spatial_ref_sys.sql for example).
> --strk;
Fine with me for trunk (bear in mind that it will probably be you that
has to answer most of the support requests for it ;)
Don't forget to add any suitable documentation as well.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
