[postgis-devel] The best way of adding the raster code
Jorge Arévalo
jorge.arevalo at deimos-space.com
Thu Sep 23 10:17:44 PDT 2010
2010/9/23 Jorge Arévalo <jorge.arevalo at deimos-space.com>:
> Hello,
> I'm adding the WKT Raster [1] (now PostGIS raster) code to the PostGIS
> trunk. I've created a separated folder, named "raster" in the PostGIS
> root. All the raster stuff is inside that folder. Then, I've added
> some macros on configure.ac, to configure the PostGIS Raster sources
> *only* if "--with-raster" option is provided at configure time.
> I've modified the GNUMakefile file to add the raster rules, but the
> point is I only want these rules added when I explicity say (with
> "--with-raster" option) I DO want to compile raster stuff at configure
> time.
> So, what's the best solution here? I want to cause the less impact to
> the current PostGIS source code, of course.
> Thanks in advance, and best regards,
[1] http://trac.osgeo.org/postgis/wiki/WKTRaster
Sorry, I forgot to say my idea is I should create a Makefile.in file
at root level, and allow ./configure to generate raster stuff only in
case "--with-raster" option is provided. But I'm not sure.
Thanks again,
Jorge Arévalo
Internet & Mobilty Division, DEIMOS
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
