[postgis-devel] Turning GSERIALIZED on
Paul Ramsey
pramsey at opengeo.org
Fri Jun 10 10:52:07 PDT 2011
Primarily it changes the underlying disk serialization (so requires
dump/restore of existing databases) and moves from using BOX2DFLOAT4
to GBOX for most box operations. Grep for GSERIALIZED_ON to see the
parts of the code base that change in the ./postgis directory.
P.
On Fri, Jun 10, 2011 at 1:32 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca> wrote:
> Could you briefly describe this change and how you think it should impact raster?
> Thanks,
> Pierre
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>> bounces at postgis.refractions.net] On Behalf Of Paragon Corporation
>> Sent: Friday, June 10, 2011 1:30 PM
>> To: 'PostGIS Development Discussion'
>> Subject: Re: [postgis-devel] Turning GSERIALIZED on
>> If raster folks and strk are okay with it, I'm okay with it.
>> So a reserved +1
>> Regina
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
>> Ramsey
>> Sent: Friday, June 10, 2011 1:19 PM
>> To: PostGIS Development Discussion
>> Subject: [postgis-devel] Turning GSERIALIZED on
>> I'd like to turn on the flag on the weekend and start cleaning up bugs next week.
>> FYI, this will probably harm topology and raster more than anyone else. What
>> will happen is I'll turn on the flag and alter the
>> 4-5 regression tests (things like memsize and a couple minor representation
>> changes) that don't pass with the flag. Then I'll kill big bugs during the week and
>> work through tickets. In succeeding weeks once things are calmed down I will
>> change things that are currently #defined (the BOX2FLOAT4 -> GBOX transition)
>> into the "real thing" and remove some code we don't need anymore (old WKT
>> parser).
>> P.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
