[postgis-devel] [PostGIS] #957: raster regress errors, SELECT and some gdal
PostGIS trac at osgeo.org
Tue May 17 08:11:50 PDT 2011
 Reporter:  strk            |       Owner:  dustymugs
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 --- rt_asgdalraster_expected    2011-05-17 09:50:39.000000000 +0200
 +++ /tmp/pgis_reg_9436/test_10_out      2011-05-17 17:05:26.000000000
 +0200
 @@ -11,5 +11,5 @@
  f0de16a21de438249ec0bbd28eafe63c
  ed4e4d60d2ccc82c4597e80c1f97272f
  83b6012757444ff7786b5e8473e6cea3
 -b699be9f7045656edbb14ecec1c75b5a
 -96a96f9a6d31544dfc5ba5cd25f40934
 +f6fa7f8ae3c35c137a75acc855255083
 +7031666f7a668577b9de9cc6a8799f75
 --- rt_summarystats_expected    2011-05-17 09:50:39.000000000 +0200
 +++ /tmp/pgis_reg_9436/test_27_out      2011-05-17 17:05:27.000000000
 +0200
 @@ -5,7 +5,7 @@
  -3.429205|6.570795
  -0.068584|1.045941
  BEGIN
 -SELECT 10
 +SELECT
  20|-3.429205|6.570795|-10|3.14159
  1000|-0.068584|1.045941|-10|3.14159
 --- rt_mean_expected    2011-05-17 09:50:39.000000000 +0200
 +++ /tmp/pgis_reg_9436/test_28_out      2011-05-17 17:05:27.000000000
 +0200
 @@ -3,7 +3,7 @@
  -3.429205
  -0.068584
  BEGIN
 -SELECT 10
 +SELECT
  -3.429205
  -0.068584
  -3.429205
 --- rt_stddev_expected  2011-05-17 09:50:39.000000000 +0200
 +++ /tmp/pgis_reg_9436/test_29_out      2011-05-17 17:05:27.000000000
 +0200
 @@ -3,7 +3,7 @@
  6.570795
  1.045941
  BEGIN
 -SELECT 10
 +SELECT
  6.570795
  1.045941
  6.570795
 The above is with PostgreSQL 8.4, PostGIS r7171, GDAL 1.9.0 on a 64bit
 system.
 I guess we should strip the 'SELECT' lines out of output.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/957>
