[postgis-devel] sql.in.c do we like not like?
Sandro Santilli strk at keybit.net
Thu Mar 28 07:48:31 PDT 2013
On Thu, Mar 28, 2013 at 09:41:28AM -0400, Paul Ramsey wrote:
> I'm not indifferent because I don't like change for change's sake.
It's not for change's sake, it's to be able to tell:
  "*.c matches C source code files"
Also, someone (Robe?) also had the benefit of syntax highlighting.
> Things were working before, let's leave them as they were.
Did you hit a failure case ? Can I help with that ?
--strk;
