[postgis-devel] Regarding Sp-gist implementation in postgis]
mohit kumar
mohitkharb at gmail.com
Mon Jul 28 03:35:14 PDT 2014
[I missed your email as I thought I am replying to the list.]
---------- Forwarded message ----------
Date: Fri, Jul 25, 2014 at 2:34 PM
Subject: Re: [postgis-devel] Regarding Sp-gist implementation in postgis
To: maplabs at light42.com
.Hi strk,
On 25 Jul 2014 13:13, "Sandro Santilli" <strk at keybit.net> wrote:
> On Fri, Jul 25, 2014 at 08:35:08AM +0530, mohit kumar wrote:
> > Thanks Brian for the help but the issue is still coming :
> > mohit at mohit-Inspiron-1545:~/builds/source/postgis$ echo "create index
on
> > points using gist(point(g));" | valgrind --leak-check=yes
> > --log-file=valgrindlog /usr/local/pgsql/bin/postgres --single postgis -D
> > /usr/local/pgsql/data/
> > FATAL: configuration file "/usr/local/pgsql/data/postgresql.conf"
contains
> > errors
> > I restarted the postgresql several times and there is no problem coming
in
> > that. The uncommented lines in the configuration
> > file(/usr/local/pgsql/data/postgresql.conf) are pasted at
> > http://pastebin.com/eaX383cw. Please let me know if I am missing
anything.
> The paths for "hba_file" and "ident_file" and "data_directory" all seem
> to be relative, so would resolve based on where you are when you start
> postgres. As you're starting it from ~/builds/source/postgis, I dubt
> you have ~/builds/source/postgis/ConfigDir, which would explain the error.
The error is coming even after removing the path for hba_file and
ident_file.
> --strk;
Regards,
On Mon, Jul 28, 2014 at 3:57 PM, Sandro Santilli <strk at keybit.net> wrote:
> [re-sent to the list, please keep the discussion here]
> on
> contains
> > errors
> in
> anything.
> --strk;
Mohit Kumar
+91-970-3840-175
Lab For Spatial Informatics
International Institute of Information Technology
Hyderabad, India
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140728/ccd2eed6/attachment.html>
