[postgis-devel] How to recreate comments?
Nicklas Avén nicklas.aven at jordogskog.no
Sun Sep 28 23:18:28 PDT 2014
Regina
>Hmm it should regenerate as part of the build process as long as the xml is
>valid and comments in right spot.  Are your comments regenerating at all?
>Might be something wrong with your docbook or xsltproc install.
>If you want to check it in I can take a look.  It just uses the refpurpose
>tag element for comment description and the function proto stuff for the
>args.
What I did was that I changed the  <paramdef> inside  <funcprototype> to match the new version with default args in twkb.
But that didn't trigger any recreation of the comments. I will take a look at my installation this evening.
Is it ok if I just commit it otherwise. That breaks the build since the upgrade script won't work without the right comments (I experienced:-) )
Thanks
Nicklas
>Regarding the create aggregate stuff, I fear you are right not much hope
>there.  I see raster ST_Union is done the same way as you describe -- repeat
>of transfn, aggs for each.
>Hope that helps,
>Regina
>http://www.postgis.us
>http://postgis.net
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at lists.osgeo.org
>http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140929/478f0ce4/attachment.html>
