[postgis-devel] 2.2.0 passes regression tests on NetBSD 6 i386, perl path issue
Greg Troxel
gdt at ir.bbn.com
Mon Oct 26 06:11:44 PDT 2015
Sandro Santilli <strk at keybit.net> writes:
> On Fri, Oct 09, 2015 at 03:44:11PM -0400, Greg Troxel wrote:
>> I updated the pkgsrc package from 2.1.7 to 2.2.0 and it passes
>> regression tests (pgsql 9.3.9, geos 3.5.0, proj 4.9.2).
>> Should I be foisting this on the pkgsrc-using world, or waiting until
>> 2.2.1? It doesn't feel urgent if that's coming within weeks.
>> One of the things I notice in packaging is changes in the set of
>> installed files. That's not a bug of course, but a chance to see if
>> the changes are entirely intended.
>> Extracts from a diff -u, with all the noise removed:
>> +include/liblwgeom_topo.h
>> +lib/postgresql/postgis_topology-2.2.so
>> -share/postgresql/contrib/postgis-2.1/topology.sql
>> -share/postgresql/contrib/postgis-2.1/topology_upgrade_21_minor.sql
>> -share/postgresql/contrib/postgis-2.1/uninstall_sfcgal.sql
>> -share/postgresql/contrib/postgis-2.1/uninstall_topology.sql
>> +share/postgresql/contrib/postgis_topology-2.2/topology.sql
>> +share/postgresql/contrib/postgis_topology-2.2/topology_upgrade.sql
>> +share/postgresql/contrib/postgis_topology-2.2/uninstall_topology.sql
>> So there's a new header, and a new library - looks intended.
>> topology stuff in contrib is in a new subdir, compard to before, but the
>> comments file didn't move down. That looks not clearly intended.
> No, it isn't intended. Could you please file a ticket ?
> It'll need to be taken care of both in 2.2 branch and trunk.
Finally filed, sorry for the delay:
https://trac.osgeo.org/postgis/ticket/3349
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20151026/66100139/attachment.sig>
