[postgis-devel] PSC Vote: Change PostGIS library name to drop the minor
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Tue Aug 29 06:25:11 PDT 2017
I've just finished my upgrade to Postgres 10.
Fixing PostGIS library name would have made the upgrade cleaner and save
some fiddling with symlinks.
Although, same problem is there for pgrouting, so you're getting used to it
https://gist.github.com/Komzpa/994d5aaf340067ccec0e
вт, 29 авг. 2017 г. в 16:20, Regina Obe <lr at pcorp.us>:
> > I'm a -1 for this. I agree with strk that this is definitely the wrong
> time to be doing this just before a release, and given that this problem
> has always existed rushing into a decision now makes little sense.
> > The different version number is there for a reason to indicate that the
> behaviour between versions will have changed, and while I understand that
> upgrading is often tricky I don't believe this is the right solution.
> > It strikes me the real issue is that something is missing from the
> upgrade process (whether that is PostGIS and/or PostgreSQL) and the focus
> on solving the issue should be placed there, and not on removing important
> version information from the generated libraries.
> > ATB,
> > Mark.
> Okay I guess that settles it. a firm -1, we can't move forward with
> this. Given no packagers have voiced any opinions whatsoever, I guess it's
> not as serious of a problem as I've heard.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170829/31f1e8b5/attachment.html>
