[postgis-devel] PostGIS Patch Releases for 2.2.7, 2.3.7, and 2.4.4
Regina Obe lr at pcorp.us
Fri Apr 6 00:05:26 PDT 2018
The PostGIS development team is pleased to provide bug fix release 2.2.7,
2.3.7 and 2.4.4 for the 2.2, 2.3, and 2.4 stable branches.
Please note that PostGIS 2.2 is reaching end-of-life and there will be one
more patch release later in the year for it.
If you have not upgraded to at least PostGIS 2.3, we encourage you do so
before we discontinue support for PostGIS 2.2.
http://postgis.net/2018/04/06/postgis-patches/
After installing the binaries or after running pg_upgrade, make sure to do:
ALTER EXTENSION postgis UPDATE;
- if you use the other extensions packaged with postgis - make sure to
upgrade those as well
ALTER EXTENSION postgis_sfcgal UPDATE;
ALTER EXTENSION postgis_topology UPDATE;
ALTER EXTENSION postgis_tiger_geocoder UPDATE;
If you use legacy.sql or legacy_minimal.sql, make sure to rerun the version
packaged with these releases.
2.2.7
Source: https://download.osgeo.org/postgis/source/postgis-2.2.7.tar.gz
NEWS:  https://svn.osgeo.org/postgis/tags/2.2.7/NEWS
PDF:  https://download.osgeo.org/postgis/docs/postgis-2.2.7.pdf
2.3.7
Source: https://download.osgeo.org/postgis/source/postgis-2.3.7.tar.gz
NEWS:  https://svn.osgeo.org/postgis/tags/23.7/NEWS
PDF:  https://download.osgeo.org/postgis/docs/postgis-2.3.7.pdf
2.4.4
Source: https://download.osgeo.org/postgis/source/postgis-2.4.4.tar.gz
NEWS:  https://svn.osgeo.org/postgis/tags/2.4.7/NEWS
PDF:  https://download.osgeo.org/postgis/docs/postgis-2.4.4.pdf
Report any issues to our bug tracker with details as noted in
http://postgis.net/support/
Thanks,
PostGIS Development Team
