[postgis-devel] [postgis-users] PostGIS 3.0.0 alpha2 released
Devrim Gündüz
devrim at gunduz.org
Wed Jun 5 09:45:57 PDT 2019
On Wed, 2019-06-05 at 14:05 +0200, Raúl Marín Rodríguez wrote:
> This was done on purpose, If postgis 3.1 comes it will be compatible
> with 3.0 (otherwise it'll be 4.0).
Ack.
> If you really need it, you can get the old behaviour back
> using `--with-library-minor-version` during configure, but the idea
> is that this shouldn't be neccesary.
Actually I don't need it. Just created another macro in the RPM spec file, and
it worked.
Thanks for the clarification!
Cheers,
Devrim Gündüz
Open Source Solution Architect, Red Hat Certified Engineer
Twitter: @DevrimGunduz , @DevrimGunduzTR
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190605/436b01de/attachment.sig>
