[postgis-devel] Enabling wagyu by default
Martin Davis
mtnclimb at gmail.com
Thu May 30 19:37:33 PDT 2019
On Thu, May 30, 2019 at 6:34 PM Regina Obe <lr at pcorp.us> wrote:
> So there is definitely interest in MVT and growing and of course such
> interest would benefit from Wagyu.
Agreed. At FOSS4GNA there seemed to be a lot of interest/usage of
ST_AsMVT. Notably by Here XYZ: https://explore.xyz.here.com
Seems like the risks of using Wagyu are (if it is not maintained by the
original developers):
- compilation problems going forward (since PostGIS is vendoring it)
- functional limitations as MVT requirements evolve
- finding issues which are showstoppers
These are mitigated by:
- it sounds like current functionality is adequate for current usage? (Are
there unit tests to assure this?)
- the fallback is to revert to using GEOS, as per before
- hopefully GEOS will provide new, robust overlay functionality soon
- GEOS can fairly easily implement the same clipping algorithm as Wagyu,
which should provide similar performance
So relying on Wagyu (for the time being) seems like a small risk, for a
large benefit.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190530/8aefbcf8/attachment.html>
