[postgis-devel] Remove Comments.sql
Regina Obe lr at pcorp.us
Wed Dec 16 16:23:50 PST 2020
> What do you suppose I spent all my time looking at? the docs? no, looking
for
> why this function that I removed is being complained about...
> Also, I want to normalize the idea that our docs won't feed into our
> extension when we change the doco format.
> P
That is clearly a bug Paul you introduced -- you should have removed the
overload from the docs if you removed it from the SQL :)
I don't mind the removal of comments -- but mind the missing of checking the
comments provides :)
