[postgis-devel] on parallel and recursive make
Sandro Santilli
strk at kbt.io
Wed Nov 4 07:20:59 PST 2020
On Wed, Nov 04, 2020 at 03:47:43PM +0100, rmrodriguez at carto.com wrote:
> On Wed, Nov 4, 2020 at 3:41 PM Sandro Santilli <strk at kbt.io> wrote:
> > Allows testing "core" tests in presence of "raster" extension
> > and "raster" tests in presence of "topology". Basically tests
> > the queries in presence of all extensions, while still allowing
> > running specific test groups by running "make check" from their
> > directories.
> Could we keep that without adding changes in the parallelism of the
> build system or is parallel testing (which are run sequentially in
> regress) a hard requirement for this feature?
Probably, how does it feel in current master, with that commit reverted ?
Note I don't think we ever had proper parallel-ready build scripts.
I'm happy if you can help with reaching that goal.
--strk;
