[postgis-devel] Pg13 upgrade issues?
Paul Ramsey
pramsey at cleverelephant.ca
Thu Sep 10 09:31:17 PDT 2020
Further to this, since it's possible to install 2.5 on Pg13, I thought I'd
check to see what a naive upgrade would look like, and it's this:
postgis25=# alter extension postgis update to '3.1.0dev';
WARNING: unpackaging raster
WARNING: PostGIS Raster functionality has been unpackaged
HINT: type `SELECT postgis_extensions_upgrade();` to finish the upgrade.
After upgrading, if you want to drop raster, run: DROP EXTENSION
postgis_raster;
ALTER EXTENSION
postgis25=# SELECT postgis_extensions_upgrade();
NOTICE: Updating extension postgis from 3.1.0dev to 2.5.5dev
ERROR: extension "postgis" has no update path from version "3.1.0dev" to
version "2.5.5dev"
CONTEXT: SQL statement "ALTER EXTENSION postgis UPDATE TO "2.5.5dev";"
PL/pgSQL function postgis_extensions_upgrade() line 68 at EXECUTE
Why the order of upgrade version gets flipped around in
postgis_extensions_upgrade() is a bit of a mystery to me.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200910/5d4d803b/attachment.html>
