[postgis-devel] Pg13 upgrade issues?
Regina Obe
lr at pcorp.us
Thu Sep 10 11:14:18 PDT 2020
Because the postgis_extensions_upgrade() takes no arguments.
It reads the latest version from postgis.config postgis-raster.config.
I suspect you installed 3.1 first and then 2.5 after. So 2.5 is considered the default.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Thursday, September 10, 2020 12:31 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] Pg13 upgrade issues?
Further to this, since it's possible to install 2.5 on Pg13, I thought I'd check to see what a naive upgrade would look like, and it's this:
postgis25=# alter extension postgis update to '3.1.0dev';
WARNING: unpackaging raster
WARNING: PostGIS Raster functionality has been unpackaged
HINT: type `SELECT postgis_extensions_upgrade();` to finish the upgrade. After upgrading, if you want to drop raster, run: DROP EXTENSION postgis_raster;
ALTER EXTENSION
postgis25=# SELECT postgis_extensions_upgrade();
NOTICE: Updating extension postgis from 3.1.0dev to 2.5.5dev
ERROR: extension "postgis" has no update path from version "3.1.0dev" to version "2.5.5dev"
CONTEXT: SQL statement "ALTER EXTENSION postgis UPDATE TO "2.5.5dev";"
PL/pgSQL function postgis_extensions_upgrade() line 68 at EXECUTE
Why the order of upgrade version gets flipped around in postgis_extensions_upgrade() is a bit of a mystery to me.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200910/1b655b8d/attachment.html>
