[postgis-devel] Pg13 upgrade issues?
Paul Ramsey
pramsey at cleverelephant.ca
Thu Sep 10 12:15:49 PDT 2020
On Thu, Sep 10, 2020 at 11:14 AM Regina Obe <lr at pcorp.us> wrote:
> I suspect you installed 3.1 first and then 2.5 after. So 2.5 is
considered the default.
OK, fixing up that, here's what actually happens (still bad)
postgis25=# alter extension postgis update to '3.1.0dev';
WARNING: unpackaging raster
WARNING: PostGIS Raster functionality has been unpackaged
HINT: type `SELECT postgis_extensions_upgrade();` to finish the upgrade.
After upgrading, if you want to drop raster, run: DROP EXTENSION
postgis_raster;
ALTER EXTENSION
postgis25=# SELECT postgis_extensions_upgrade();
NOTICE: Updating extension postgis 3.1.0dev
NOTICE: Packaging extension postgis_raster
ERROR: CREATE EXTENSION ... FROM is no longer supported
LINE 1: CREATE EXTENSION postgis_raster FROM unpackaged SCHEMA publi...
QUERY: CREATE EXTENSION postgis_raster FROM unpackaged SCHEMA public;
CONTEXT: PL/pgSQL function postgis_extensions_upgrade() line 57 at EXECUTE
postgis25=#
So, as expected, the raster repackaging step fails because "from
unpackaged" has been removed.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200910/82851707/attachment.html>
