[postgis-devel] Pg13 upgrade issues?
Paul Ramsey pramsey at cleverelephant.ca
Fri Sep 18 11:45:40 PDT 2020
> On Sep 17, 2020, at 3:36 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> On Sep 15, 2020, at 10:05 AM, Sandro Santilli <strk at kbt.io> wrote:
>> packaged` suffix.
>>> I tried your PR, and the core idea of a fake 'unpackaged' target seems miraculously to work, so there's just some polish to be added to the PR as far as I can tell. What do you feel are the drawbacks of it? The further we get away from 2.X, the less the "hackiness" of the solution matters in practical terms.
>> I don't see drawbacks other than the "hackish" mode.
>> If you like that model, we can as well go for it.
>> If not else, it's ready...
> I'm fine w/ hackish, I think the PR needs some more work still, but I like that it mostly solves the problem.
> I have some additions to your branch here:
> https://git.osgeo.org/gitea/pramsey/postgis/src/branch/recover-unpackaged-tests
I've added some changes in run_test.paul and can now run 'make installcheck' all the way through. PR with CI here: https://github.com/postgis/postgis/pull/578
> (I couldn't figure out how to submit a PR to your working branch. Maybe we can/should collab on a branch in the postgis repo?)
> P
