[postgis-devel] protobuf version?
Paul Ramsey
pramsey at cleverelephant.ca
Fri Sep 18 13:07:41 PDT 2020
The syntax used in the vector_tiles.proto file has moved up to a version not compatible with the libraries shipped with RHEL/Centos 7.
https://github.com/postgis/postgis/commit/99c50d4602a6e1d94f65932cbcbee933af998ea1#r42442986
Are we wedded to using the new feature (which seems like just a safety feature, and our code should be sufficiently disciplied to follow the oneof rule without having to specify it in the proto file).
P.
