[postgis-devel] Docker postgis-build-env ?
Paul Ramsey
pramsey at cleverelephant.ca
Mon Apr 11 10:11:02 PDT 2022
> On Apr 11, 2022, at 10:09 AM, Regina Obe <lr at pcorp.us> wrote:
>> Someome updated and pushed these recently (2 days ago?) there seems to be
>> something awry in the GDAL and CGAL shipping with some of them, which is
>> causing CI failures on CI that depends on them (GitHub Actions)
>> https://hub.docker.com/repository/docker/postgis/postgis-build-env
>> See the results in this PR for example.
>> https://github.com/postgis/postgis/pull/682
>> P
> [Regina Obe]
> This happens weekly by a Jenkins job. GH actions had been broken for a
> while but was fixed recently and had nothing to do with the docker builds.
> Turns out it was caused by the LTO change.
> Detailed here - https://trac.osgeo.org/postgis/ticket/5121
> Are you still seeing breaks somewhere? Last I checked GH actions is fine.
Very not fine. I noticed the breakage against Even's WKT PR <
https://github.com/postgis/postgis/pull/682>, and the breaks have nothing to do with his work and everything to do with the environment on a few images seeming to have problems. And the commit history in the repo in general shows things bring broken for quite a while.
https://github.com/postgis/postgis/commits/master
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
