[postgis-devel] Docker postgis-build-env ?
Regina Obe
lr at pcorp.us
Mon Apr 11 10:14:24 PDT 2022
> > On Apr 11, 2022, at 10:09 AM, Regina Obe <lr at pcorp.us> wrote:
> >> Someome updated and pushed these recently (2 days ago?) there seems
> >> to be something awry in the GDAL and CGAL shipping with some of them,
> >> which is causing CI failures on CI that depends on them (GitHub
> >> Actions)
> >> https://hub.docker.com/repository/docker/postgis/postgis-build-env
> >> See the results in this PR for example.
> >> https://github.com/postgis/postgis/pull/682
> >> P
> > [Regina Obe]
> > This happens weekly by a Jenkins job. GH actions had been broken
> > for a while but was fixed recently and had nothing to do with the docker
> builds.
> > Turns out it was caused by the LTO change.
> > Detailed here - https://trac.osgeo.org/postgis/ticket/5121
> > Are you still seeing breaks somewhere? Last I checked GH actions is
fine.
> Very not fine. I noticed the breakage against Even's WKT PR <
> https://github.com/postgis/postgis/pull/682>, and the breaks have nothing
to
> do with his work and everything to do with the environment on a few images
> seeming to have problems. And the commit history in the repo in general
> shows things bring broken for quite a while.
> https://github.com/postgis/postgis/commits/master
[Regina Obe]
Looks fine to me
https://github.com/postgis/postgis/runs/5976528089?check_suite_focus=true
I only patched the LTO over the weekend I think so I suspect all prior runs
were using the forced LTO.
