[postgis-devel] Docker postgis-build-env ?
Paul Ramsey
pramsey at cleverelephant.ca
Mon Apr 11 10:52:50 PDT 2022
OK then seems to be green again. ;)
On Mon, Apr 11, 2022 at 10:14 AM Regina Obe <lr at pcorp.us> wrote:
> > > On Apr 11, 2022, at 10:09 AM, Regina Obe <lr at pcorp.us> wrote:
> > >> Someome updated and pushed these recently (2 days ago?) there seems
> > >> to be something awry in the GDAL and CGAL shipping with some of them,
> > >> which is causing CI failures on CI that depends on them (GitHub
> > >> Actions)
> > >> https://hub.docker.com/repository/docker/postgis/postgis-build-env
> > >> See the results in this PR for example.
> > >> https://github.com/postgis/postgis/pull/682
> > >> P
> > > [Regina Obe]
> > > This happens weekly by a Jenkins job. GH actions had been broken
> > > for a while but was fixed recently and had nothing to do with the docker
> > builds.
> > > Turns out it was caused by the LTO change.
> > > Detailed here - https://trac.osgeo.org/postgis/ticket/5121
> > > Are you still seeing breaks somewhere? Last I checked GH actions is
> fine.
> > Very not fine. I noticed the breakage against Even's WKT PR <
> > https://github.com/postgis/postgis/pull/682>, and the breaks have nothing
> to
> > do with his work and everything to do with the environment on a few images
> > seeming to have problems. And the commit history in the repo in general
> > shows things bring broken for quite a while.
> > https://github.com/postgis/postgis/commits/master
> [Regina Obe]
> Looks fine to me
> https://github.com/postgis/postgis/runs/5976528089?check_suite_focus=true
> I only patched the LTO over the weekend I think so I suspect all prior runs
> were using the forced LTO.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
