[postgis-devel] PSC Vote: Push out micro updates for PostGIS 3.2.2, 3.1.6, and 3.0.6
Regina Obe
lr at pcorp.us
Wed Jul 13 17:38:45 PDT 2022
It's been a while since we released.
I'd like to get out a micro update release for 3.2.2, 3.1.6, and 3.0.6 in
about a week from now.
+1 from me.
Items slated for release are below for 3.2.2 (the 3.1.6 and 3.0.6 are a
subset of these)
- #5182, Fix loading topology.sql in new database (Sandro Santilli)
- #4835, Occasional distance errors in polar area (Paul Ramsey)
- #5124, GRANT USAGE on topology schema to PUBLIC (Sandro Santilli)
- #5120, Fix not-null result from ST_EstimatedExtent against
truncated tables with spatial index (Sandro Santilli)
- #5115, Allow dropping topologies with pending constraints
(Sandro Santilli)
- #5105, Fix false invalidity report from ValidateTopology
(Sandro Santilli)
- #5039, postgis_tiger_geocoder: Support for TIGER 2021 (Regina Obe)
- #5097, Ensure spatial index is used during topology population
at the getClosestEdge step (Sandro Santilli)
- #5091, Fix --without-protobuf builds (Tobias Bussmann)
- #5100, Don't use pg_atoi (removed in PG15) (Laurenz Albe)
- #5114, Crash with long column names pgsql2shp (Paul Ramsey)
- #5123, Support for PG15 (JSON funcs exposed) (Regina Obe)
- #5125, Fix search path function (Sandro Santilli)
- #5150, Change signature of AddToSearchPath (Regina Obe)
- #5151, ST_SetPoint with empty geometries (Regina Obe)
- #5152, Fix infinite loop with ST_Split (Sandro Santilli)
- #5173, Crash creating flatgeobuf on row without geometry (Julien
Rouhaud)
- #4541, ST_ConcaveHull returns a "geometrycollection" type instead of the
expected "polygon"
