[postgis-devel] PSC Vote: Push out micro updates for PostGIS 3.2.2, 3.1.6, and 3.0.6
Paul Ramsey pramsey at cleverelephant.ca
Thu Jul 14 11:54:45 PDT 2022
+1 !!
> On Jul 13, 2022, at 5:38 PM, Regina Obe <lr at pcorp.us> wrote:
> It's been a while since we released.
> I'd like to get out a micro update release for 3.2.2, 3.1.6, and 3.0.6 in
> about a week from now.
> +1 from me.
> Items slated for release are below for 3.2.2 (the 3.1.6 and 3.0.6 are a
> subset of these)
>  - #5182, Fix loading topology.sql in new database (Sandro Santilli)
>  - #4835, Occasional distance errors in polar area (Paul Ramsey)
>  - #5124, GRANT USAGE on topology schema to PUBLIC (Sandro Santilli)
>  - #5120, Fix not-null result from ST_EstimatedExtent against
>           truncated tables with spatial index (Sandro Santilli)
>  - #5115, Allow dropping topologies with pending constraints
>           (Sandro Santilli)
>  - #5105, Fix false invalidity report from ValidateTopology
>           (Sandro Santilli)
>  - #5039, postgis_tiger_geocoder: Support for TIGER 2021 (Regina Obe)
>  - #5097, Ensure spatial index is used during topology population
>           at the getClosestEdge step (Sandro Santilli)
>  - #5091, Fix --without-protobuf builds (Tobias Bussmann)
>  - #5100, Don't use pg_atoi (removed in PG15) (Laurenz Albe)
>  - #5114, Crash with long column names pgsql2shp (Paul Ramsey)
>  - #5123, Support for PG15 (JSON funcs exposed) (Regina Obe)
>  - #5125, Fix search path function (Sandro Santilli)
>  - #5150, Change signature of AddToSearchPath (Regina Obe)
>  - #5151, ST_SetPoint with empty geometries (Regina Obe)
>  - #5152, Fix infinite loop with ST_Split (Sandro Santilli)
>  - #5173, Crash creating flatgeobuf on row without geometry (Julien
> Rouhaud)
>  - #4541, ST_ConcaveHull returns a "geometrycollection" type instead of the
> expected "polygon"
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
