New Contributor
Andrew Koure
andrew at koure.org
Wed Oct 8 18:58:13 PDT 2025
Hello,
I'm working on my first contribution to PostGIS. I picked up this issue
from trac: #5889 (Include location in topology errors) – PostGIS
<https://trac.osgeo.org/postgis/ticket/5889#no4>. And have a WIP pull
request here: https://gitea.osgeo.org/postgis/postgis/pulls/273
The regress pipeline check failed because the docker container ran out of
disk space, or at least that's what I'm taking away from this error: Error
response from daemon: open
/var/lib/docker/vfs/dir/9ea4ee7529a19d4c31fdd7b63375c9d38cae9e81d10f6dba989159143e04a97f/usr/lib/postgresql/13/lib/bitcode/amcheck/verify_nbtree.bc:
disk quota exceeded
This was for check 13, 14, 15, 17 and also for installcheck. Is it possible
to re-trigger these workflows?
Also I've been having some trouble getting the C formatter in VSCode/CLion
to behave as every time the formatter runs it changes 90% of the file.I'm
not sure if the formatters are ignoring the .clang-format file or not?
I'm somewhat new to C development so any tips would also be helpful,
especially if there are some small but impactful issues that could be
tackled.
Best,
Andrew Koure
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20251008/2f1973b4/attachment.htm>
