Remove postgis_tiger_geocoder and address_standardizer from the PostGIS code base
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Fri Feb 20 10:30:54 PST 2026
+1 on splitting these out.
They aren't really useful as-is outside of US or English-speaking regions.
Over here people roll with libpostal, nominatim and pg_trgm based homebrew
geocoder variations.
With the recent addition of h3_pg we have an example of having separate
repos for separate extensions so now it can improve on the general layout
of all the extension repos.
On Thu, Feb 19, 2026 at 2:10 AM Regina Obe <lr at pcorp.us> wrote:
> I'd like to remove postgis_tiger_geocoder and address_standardizer from the
> PostGIS code base and spin those off as separate project repos.
> They would be still under the postgis gitea org, just not in PostGIS repo.
> The reasoning is this.
> 1) They don't really use the PostGIS regress/install machinery. They use
> the PostgreSQL regress and make installcheck
> 2) The cycle at which we change these is different.
> a) postgis_tiger_geocoder changes whenever census data changes, so doesn't
> make sense to follow PostGIS release cycle. It also is all plpgsql code and
> doesn't use any of the newer functions of PostGIS so can work with pretty
> much any postgis version
> b) address_standardizer has no dependence what so ever on PostGIS core and
> the release cycle is much less frequent than postgis proper.
> How badly will this mess up work of packagers?
> I'm thinking doing this for the PostGIS 3.7 cycle.
> Thanks,
> Regina
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20260220/69fb88b8/attachment-0001.htm>
