[postgis-tickets] [PostGIS] #2396: liblwgeom CUnit tests fail on big-endian architectures.
trac at osgeo.org
Sun Aug 4 09:45:47 PDT 2013
Reporter: mnencia | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.4
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by robe):
Well 1478 seems to be the endian issue since:
SELECT ST_OrderingEquals(ST_GeomFromEWKT('00200000040000000100000000'),
ST_GeomFromEWKT('01040000200100000000000000'))
returns true for me (can you verify it returns true for you?_ so they are
the same geometry. Looks like 1755 is same endian issue. So painful
solution I would guess is to make our tests endian agnostic.
pramsey -- are you around to venture an opinion on this issue?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2396#comment:14>
