[postgis-tickets] [PostGIS] #2111: [raster] External band numbers are capped to 1 - 256
trac at osgeo.org
Sun Aug 4 10:10:50 PDT 2013
Reporter: dustymugs | Owner: dustymugs
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: |
Comment(by dustymugs):
Should there be RFCs for changing the raster's serialized and WKB formats?
The only changes I plan on making is bumping up the format version numbers
to 1 and change the variable type for out-db band indexes from uint8 to
uint16.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2111#comment:7>
