[postgis-tickets] [PostGIS] #2396: liblwgeom CUnit tests fail on big-endian architectures.
PostGIS trac at osgeo.org
Tue Aug 6 09:02:50 PDT 2013
 Reporter:  mnencia  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by robe):
 revised at r11738 for 2.1.
 Okay in looking at this.  I just noticed this particular test:
  Test: test_lwgeom_force_clockwise ... FAILED
     1. cu_libgeom.c:750  - CU_ASSERT_STRING_EQUAL(in_ewkt,out_ewkt)
 uses compare of wkbs which could be endian specific instead of the ewkt
 compare.  I've run into situations like this and switched these tests to
 do a same check (which is more or less equivalent to ST_OrderingEquals).
 The output fprintf is something we generally only do when we are debugging
 a test and not in the final iteration of a test. Though makes sense for us
 to include as part of test as a cross-check.  That is neither here nor
 there.  As a quick fix, I'm just getting rid of the fprintf and making it
 a standard same ASSERT check.
 Paul can change back if he feels the need to be more verbose.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2396#comment:16>
