[postgis-tickets] [PostGIS] #2408: regress failure on windows 7 32-bit 9.3 beta 1 EDB
trac at osgeo.org
Tue Aug 6 09:20:49 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Keywords: |
Related to this ticket, I too am getting failures on my windows 7 32-bit
9.3 setup:
PostgreSQL 9.3beta1, compiled by Visual C++ build 1600, 32-bit
- 2013-08-06 15:25:47
GEOS: 3.4.0dev-CAPI-1.8.0 r3829
PROJ: Rel. 4.8.0, 6 March 2012
Running tests
loader/Point .............. ok
loader/PointM .............. ok
loader/PointZ .............. ok
loader/MultiPoint .............. ok
loader/MultiPointM .............. ok
loader/MultiPointZ .............. ok
loader/Arc .............. ok
loader/ArcM .............. ok
loader/ArcZ .............. ok
loader/Polygon .............. ok
loader/PolygonM .............. ok
loader/PolygonZ .............. ok
loader/TSTPolygon ......... ok
loader/TSIPolygon ......... ok
loader/TSTIPolygon ......... ok
loader/PointWithSchema ..... ok
loader/NoTransPoint ......... ok
loader/NotReallyMultiPoint ......... ok
loader/MultiToSinglePoint ......... ok
loader/ReprojectPts ........ ok
loader/ReprojectPtsGeog ........ ok
loader/Latin1 .... ok
binary .. ok
regress .. ok
regress_index .. ok
regress_index_nulls .. failed (diff expected obtained:
/projects/postgis/tmp/2.
1.0_pg9.3w32/test_26_diff)
regress_selectivity .. ok
lwgeom_regress .. ok
regress_lrs .. ok
removepoint .. ok
setpoint .. ok
simplify .. ok
snaptogrid .. ok
summary .. ok
affine .. ok
empty .. ok
measures .. ok
legacy .. ok
long_xact .. ok
ctors .. ok
sql-mm-serialize .. ok
sql-mm-circularstring .. ok
sql-mm-compoundcurve .. ok
sql-mm-curvepoly .. ok
sql-mm-general .. ok
sql-mm-multicurve .. ok
sql-mm-multisurface .. ok
polyhedralsurface .. ok
polygonize .. ok
postgis_type_name .. ok
geography .. ok
out_geometry .. ok
out_geography .. ok
in_geohash .. ok
in_gml .. ok
in_kml .. ok
iscollection .. ok
regress_ogc .. ok
regress_ogc_cover .. ok
regress_ogc_prep .. ok
regress_bdpoly .. ok
regress_proj .. ok
regress_management .. ok
dump .. ok
dumppoints .. ok
boundary .. ok
wmsservers .. ok
wkt .. ok
wkb .. ok
tickets .. failed (diff expected obtained:
/projects/postgis/tmp/2.1.0_pg9.3w32
/test_70_diff)
typmod .. ok
remove_repeated_points .. ok
split .. ok
relate .. ok
bestsrid .. ok
concave_hull .. ok
hausdorff .. ok
regress_buffer_params .. ok
offsetcurve .. ok
relatematch .. ok
isvaliddetail .. ok
sharedpaths .. ok
snap .. ok
node .. ok
unaryunion .. ok
clean .. ok
relate_bnr .. ok
delaunaytriangles .. ok
in_geojson .. ok
)uninstall .. ok (4112
Run tests: 90
Failed: 2
Makefile:203: recipe for target `check' failed
make[1]: *** [check] Error 2
make[1]: Leaving directory `/projects/postgis/branches/2.1/regress'
GNUmakefile:14: recipe for target `check' failed
make: *** [check] Error 1
--- regress_index_nulls_expected 2013-07-09 12:31:43 -0400
+++ /projects/postgis/tmp/2.1.0_pg9.3w32/test_26_out 2013-08-06
11:30:43 -0400
@@ -1,4 +1,6 @@
NOTICE: table "indexnulls" does not exist, skipping
+ERROR: parse error - invalid geometry at character 88
+ERROR: parse error - invalid geometry at character 87
NOTICE: table "indexempty" does not exist, skipping
--- tickets_expected 2013-07-09 12:31:30 -0400
+++ /projects/postgis/tmp/2.1.0_pg9.3w32/test_70_out 2013-08-06
11:30:57 -0400
@@ -121,7 +121,7 @@
ERROR: Shell is not a line
#695
ERROR: First argument must be a LINESTRING
-#696|010F000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000000001030000800100000005000000000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F00000000000000000000000000000000000000000000F03F000000000000F03F0000000000000000010300008001000000050000000000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F000000000000F03F000000000000F03F000000000000F03F000000000000F03F000000000000F03F000000000000F03F00000000000000000000000000000000000000000000F03F00000000000000000103000080010000000500000000000000000000000000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F00000000000000000000000000000000000000000000F03F
#720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91
11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45
11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82
11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18
11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54
11028513.63)
#723|0101000020E61000006284F068E33826C00000000000004440
#723|0107000020E610000000000000
@@ -219,7 +219,7 @@
#1697.2|0
#1697.3|1024
#1734.1|1026
-#1755|01010000A0E6100000000000000040554000000000008041400000000000000000
#1776|POLYGON((0 0,10 0,10 10,0 0))|POLYGON((0 0,10 0,10 10,0 0))
#1780|t
#1791|4.7
test 26 seems like harmless character position difference but the tickets
(test 70) has me a bit concerned.
I'm going to retest with beta2 to see if the error goes away
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2408>
