[postgis-tickets] [PostGIS] #2407: st_linetocurve and st_curvetoline behaviour change
PostGIS trac at osgeo.org
Wed Aug 7 02:21:55 PDT 2013
 Reporter:  mjurce   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by strk):
 Oops, sorry for the noise, r8689 has nothing to do with curves, will need
 to bisect this.
 Mario: I don't understand what's the input to ST_LineToCurve, because
 passing the output from ST_CurveToLine(your_input) to ST_LineToCurve gives
 me an exception in both trunk and 1.5.
 The exception from trunk:
 ERROR:  pta_desegmentize needs implementation for npoints < 4
 The exception from 1.5:
 ERROR:  getPoint4d_p: point offset out of range
 The result of ST_CurveToLine in 1.5:
  MULTILINESTRING((723097.524 117088.672,724308.441 117063.281),(724308.441
 117063.281,724342.841215728 117105.022471111,724379.2481518
 117145.02572421,724417.574100719 117183.194387956,724457.726731915
 117219.436510696,724499.609314185 117253.66478198,724543.120948718
 117285.796742906,724588.156812175 117315.754984765,724634.608409218
 117343.467335528,724682.36383388 117368.867033715,724731.30803916
 117391.892889229,724781.323114181 117412.489430767,724832.288568246
 117430.607039456,724884.081621113 117446.20206839,724936.57749878
 117459.236947778,724989.649734079 117469.680275453,725043.170471349
 117477.506892526,725097.010774444 117482.69794399,725151.040937359
 117485.240924147,725205.130796698 117485.129706735,725259.150045253
 117482.364559687,725312.968545923 117476.952144484,725366.456645225
 117468.905500109,725419.485485643 117458.244011632,725443.148 117452.604))
 The result of ST_CurveToLine  with trunk:
 It would help to have a smaller input geometry still reproducing the
 problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2407#comment:2>
