[postgis-tickets] [PostGIS] #2407: st_linetocurve and st_curvetoline behaviour change
PostGIS trac at osgeo.org
Wed Aug 7 05:56:47 PDT 2013
 Reporter:  mjurce   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by strk):
 Note that the WKT you report as the "old result" is invalid, could you re-
 paste it wrapping it within three curly brackets (it's the syntax for
 preformatted text) ?
 My results of 1.5 are specifically from 1.5.9-svn. The number of points in
 the result are the same (so same number of arcs). The coordinates aren't
 all the same, but the furthest points (hausdorff distance) are 1e-10
 apart.
 Difference in length of the two results is computed to be around 4e-12.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2407#comment:3>
