[postgis-tickets] [PostGIS] #2407: st_linetocurve and st_curvetoline behaviour change
PostGIS trac at osgeo.org
Wed Aug 7 06:05:31 PDT 2013
 Reporter:  mjurce   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by strk):
 I think I found how to interpret the reported result for 1.5.x (removing
 some space padding):
 MULTILINESTRING((723097.524 117088.672,724308.441
 117063.281,724342.841215729 117105.022471112,724379.248151801
 117145.025724211,724417.57410072 117183.194387958,724457.726731918
 117219.436510698,724499.609314188 117253.664781983,724543.120948721
 117285.796742909,724588.15681218 117315.754984769,724634.608409223
 117343.467335533,724682.363833886 117368.867033721,724731.308039167
 117391.892889235,724781.323114189 117412.489430773,724832.288568255
 117430.607039462,724884.081621122 117446.202068396,724936.577498789
 117459.236947784,724989.64973409 117469.680275461,725043.1704
 7136117477.506892534,725097.010774456 117482.697943997,725151.040937372
 117485.240924154,725205.130796712 117485.129706743,725259.150045268
 117482.364559695,725312.968545938 117476.952144492,725366.456645242
 117468.905500116,725419.485485661 117458.244011639,725443.148 117452.604))
 The reported geometry indeed has only 26 vertices while the one I obtained
 with 1.5.9-svn and the one with trunk (2.2) has 27 vertices. Did the
 behavior maybe change already in the 1.5 branch ? I'll try to obtain the
 26 vertices with an older version.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2407#comment:4>
