[postgis-tickets] [PostGIS] #2418: st_isvalid crashes postgres
PostGIS trac at osgeo.org
Fri Aug 9 13:52:02 PDT 2013
 Reporter:  crispond    |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:  Management 2.0
Component:  postgis     |     Version:  2.0.x
 Keywords:  st_isvalid  |
 If you run the following, it takes down the postgres service:
 select st_isvalid(null);
 select st_isvalid('sometext');
 My apologies if this has already been resolved or is miscategorised.  I
 thought it was important to report since it took out the postgres.exe
 processes completely.
 -cris
 Stats:
 PostgreSQL 9.1.5, compiled by Visual C++ build 1500, 64-bit POSTGIS="2.0.1
 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL
 1.9.1, released 2012/05/15" LIBXML="2.7.8" LIBJSON="UNKNOWN" TOPOLOGY
 RASTER
 I'm running windows 7 ultimate 64 bit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2418>
