[postgis-tickets] [PostGIS] #2418: st_isvalid crashes postgres
trac at osgeo.org
Fri Aug 9 18:18:54 PDT 2013
Reporter: crispond | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: Management 2.0
Component: postgis | Version: 2.0.x
Resolution: duplicate | Keywords: st_isvalid
Changes (by robe):
* status: new => closed
* resolution: => duplicate
Comment:
Yes this is a known issue related to #2338. Its a family of issues.
Unfortunately fixing it in 9.1/9.2 64-bit requires me to change quite a
few libraries (GEOS, Proj etc.). I can provide binary fixes if you need
it badly.
The fix for this issue I have in 9.3 x64-bit releases for 2.1 moving
forward. I don't plan to fix prior versions at least until 9.3 has been
out in the field for a bit to make sure I'm not swapping one set of issues
for another.
Fixing for prior versions may break peoples installs where they have both
2.0/2.1 installed since it would require upgrade of both.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2418#comment:1>
