[postgis-tickets] [PostGIS] #2417: pgsql2shp doesnt see SRID
PostGIS trac at osgeo.org
Fri Aug 9 18:29:56 PDT 2013
  Reporter:  darkblueb  |       Owner:  pramsey
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 2.1.0
 Component:  postgis    |     Version:  2.0.x
Resolution:  wontfix    |    Keywords:  srid, pgsql2shp
Changes (by robe):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 This affects 2.0 as well I think, but I don't want to fix it this round
 and not sure I want to fix it so I'm going to mark as a won't fix.
 The issue is that now that geometry_columns contains all tables
 (registered), it will look in the geometry_columns table for the srid and
 since you didn't make it a typed geometry, the srid will be 0 and wil be
 found.  If I were to fix this issue it would make the dump slower for
 large tables taht are untyped since it wil fal into teh DISTINCT check
 trap.  I think to resolve, just best to follow best practice rather than
 change this behavior.
 Try creating your table as follows:
 CREATE TABLE shp_test AS VALUES ('Example',
 ST_SetSRID(ST_MakePoint(-122.427159, 37.760028),
 4236)::geometry(point,4326));
 and I bet it will work as you expect.
 or if you really want the srid, then use SQL so it won't find the wrong
 answer in geometry_columns
 pgsql2shp -f test_shapefile.shp "SELECT * from ne3_test" shp_test
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2417#comment:1>
