[postgis-tickets] [PostGIS] #2417: pgsql2shp doesnt see SRID
trac at osgeo.org
Fri Aug 9 21:49:47 PDT 2013
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Resolution: | Keywords: srid, pgsql2shp
Changes (by darkblueb):
* status: closed => reopened
* resolution: wontfix =>
Comment:
''... since you didn't make it a typed geometry, the srid will be 0...''
the SRID is embedded in the geometry
ne3_test=# select column2 from shp_test ;
column2
01010000208C1000004BCCB392569B5EC0AB05F69848E14240
(1 row)
ne3_test=# select
st_asewkt('01010000208C1000004BCCB392569B5EC0AB05F69848E14240'::geometry);
st_asewkt
SRID=4236;POINT(-122.427159 37.760028)
(1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2417#comment:2>
