[postgis-tickets] [PostGIS] #2420: ST_LineToCurve turns squares into circles
PostGIS trac at osgeo.org
Sun Aug 11 07:26:46 PDT 2013
 Reporter:  strk     |       Owner:  strk
     Type:  defect   |      Status:  assigned
 Priority:  medium   |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Changes (by strk):
  * milestone:  PostGIS 2.2.0 => PostGIS 2.0.4
Comment:
 I'm thinking for a start it won't accept a parameter, but will hard-code a
 minimum number of required edges to define an arc. Do you see any problem
 with that ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2420#comment:4>
