[postgis-tickets] [PostGIS] #2420: ST_LineToCurve turns squares into circles
trac at osgeo.org
Sun Aug 11 08:42:07 PDT 2013
Reporter: strk | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.4
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by robe):
It's only a problem if you consider the prior behavior a bug that needs
fixing. Sounds like you are saying its simply not the expected behavior
(though not a bug), you as a user would expect. Then you are changing
behavior in a micro (that is not a bug) -- a bit of a no no.
It's also an issue if it requires a fair amount of changing. We don't
have it in our guideliines, but there is an unknown point in complexity of
code where we have to say let old dogs lie.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2420#comment:5>
