[postgis-tickets] [PostGIS] #2422: geography regression difference
trac at osgeo.org
Sun Aug 11 17:38:14 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.1.x
Keywords: |
I presume geography in 2.0.4 and goegraphy in 2.1 should return the same
answer. In benchmarking client's dat I found something slighly troubling:
SELECT COUNT(*) FROM face
WHERE ST_DWithin(geog, st_setsrid(st_makepoint(-71.0636, 42.3584),
4326)::geography, 1609.344 );
when I run this on
POSTGIS="2.0.4SVN r11708" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0,
6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER PostgreSQL 9.2.4, compiled by Visual C++ build
1600, 64-bit
count
397
(1 row)
Time: 157.613 ms
On
POSTGIS="2.1.0rc2 r11726" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0,
6 Mar
LIBJSON="UNKNOWN
" RASTER PostgreSQL 9.2.4, compiled by Visual C++ build 1600, 64-bit
count
395
(1 row)
Time: 218.903 ms
whammo I got 2 geometries less and lost a good chunk of speed.
I ran a couple of times on each database with similar timings.
I'll try to get permission from client to release this datasource, but in
mean time I'll try to narrow down to the offending geometries.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2422>
