[postgis-tickets] [PostGIS] #2422: geography regression difference
trac at osgeo.org
Sun Aug 11 17:43:29 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.1.x
Keywords: |
Description changed by robe:
Old description:
> I presume geography in 2.0.4 and goegraphy in 2.1 should return the same
> answer. In benchmarking client's dat I found something slighly
> troubling:
> SELECT COUNT(*) FROM face
> WHERE ST_DWithin(geog, st_setsrid(st_makepoint(-71.0636, 42.3584),
> 4326)::geography, 1609.344 );
> when I run this on
> POSTGIS="2.0.4SVN r11708" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0,
> 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
> LIBJSON="UNKNOWN" RASTER PostgreSQL 9.2.4, compiled by Visual C++ build
> 1600, 64-bit
> count
> 397
> (1 row)
> Time: 157.613 ms
> On
> POSTGIS="2.1.0rc2 r11726" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel.
> 4.8.0, 6 Mar
> LIBJSON="UNKNOWN
> " RASTER PostgreSQL 9.2.4, compiled by Visual C++ build 1600, 64-bit
> count
> 395
> (1 row)
> Time: 218.903 ms
> whammo I got 2 geometries less and lost a good chunk of speed.
> I ran a couple of times on each database with similar timings.
> I'll try to get permission from client to release this datasource, but in
> mean time I'll try to narrow down to the offending geometries.
New description:
answer. In benchmarking client's data I found something slightly
troubling:
when I run this on
1600, 64-bit
count
397
(1 row)
Time: 157.613 ms
On
POSTGIS="2.1.0rc2 r11726" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0,
6 Mar
LIBJSON="UNKNOWN
count
395
(1 row)
Time: 218.903 ms
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2422#comment:1>
